by fastj22 » Thu Apr 09, 2015 7:05 pm
I installed a simple bias spring system. The springs are attached to the aileron rods with a hose clamp. The other end goes via a small cable around a 12V motor with a winch/spool drum to the other spring. I control which spring is stretched with a high hat control on my stick. So a few clicks of the hat left or right, and the spool pulls the cable and spring on the heavy side. I installed a similar system for my elevator trim replacing the dial a trim. So when I need to trim out, its all on the hat. Using the springs, I can override the trim with a simple pull of the stick.
I have thought about making this a kit for other builders. Anyone interested? It would include the stick w/hat, motors, springs and relays.
