Remote Battery Charger
Postby mike.smith » Sat Apr 04, 2015 8:50 pm
I thought someone might be interested in the remote battery charger I finished installing today:
http://www.mykitlog.com/users/display_l ... 2107&row=7
http://www.mykitlog.com/users/display_l ... 6069&row=2
I wanted a way to charge the battery without removing the cowl. I took note of the ways others have done it, but I kept thinking I'd like to do it differently. This is what I came up with, and it works like a charm! Just in case I'm not around a charger that has these male/female connectors, I have an adapter I made that plugs in here, but has two traditional alligator clips that I can connect to the alligator clips on any other battery charger.
Re: Remote Battery Charger
Postby Bryan Cotton » Sun Apr 05, 2015 8:18 am
Looks good Mike! Where did you get the parts?
Postby jmtraylor » Sun Apr 05, 2015 8:57 am
Mike, can you provide the source for the bolt on socket plate? I've been looking and have never seen it. I've been looking for a solution for my Odyssey charger for a while now and your solution is the solution I've been looking for.
Mark Traylor
Sonex #1222B
Helena, AL
jmtraylor
Postby marsolgp » Sun Apr 05, 2015 9:49 am
G. Marsolais
Waiex w/Turbo Aerovee
MGL Xtreme EFIS & EMS
A/P, iFly720 w/ADS-B
marsolgp
Postby mike.smith » Sun Apr 05, 2015 1:23 pm
I got most of mine at Airventure last summer. I found a lot of these wiring systems on motorcycle web sites (they use similar batteries).
This is the end I connected downstream of the battery. I cut off the negative connector and added a fast-on to go on my ground block.
http://www.exo2theheatinside.com/produc ... cable.html
http://www.rakuten.com/prod/battery-ten ... OgodawUAzw
http://www.exo2theheatinside.com/produc ... s.html?p=2
I bought a few of the basic wires with connectors so I could end up with what I needed. One word of caution: with multiple wires and connectors the + & - get swapped. So just make sure you trace the + & - from end to end to make sure they match. I messed that up, actually, but the battery charger caught it and the "check" light went on. Swapped a + for a - and all was well again.
Postby billmaxmcw » Mon Apr 06, 2015 2:23 pm
For you KISSers out there who don't have to lock their cockpits; the canopy sits on the cord from my Batter Minder Jr. with no problems, and the plug on the battery side tucks under the dashboard with a bit of Velcro.
0406 006.JPG (219.9 KiB) Viewed 3874 times
0406 005.JPG (124.1 KiB) Viewed 3874 times
Bill, Oregon
2012 Sonex taildragger (kit)
Aerovee 2.1, Aeroinjector
billmaxmcw
Postby MichaelFarley56 » Mon Apr 06, 2015 4:28 pm
If you have an Odyssey, you can purchase a charger/maintainer from Aircraft Spruce specific to the Odyssey series. Included in the package is a hookup/extension of you don't want to use alligator clips. I attached this to the battery then snaked it down to the cowling exit area next to the breather line. Now all I need to do is plug in the charger to this line and it's good to go. No cowling removal needed!
Waiex #0056 - N569KM (sold)
Onex #245
Postby Rynoth » Mon Apr 06, 2015 6:13 pm
I plan on installing a hot 12V socket in my cockpit, both for power in flight and for hooking up a tender on the ground. Battery tender sells a 12v socket adapter for a few bucks. I wouldn't recharge the battery this way but I think it's fine for a tender.
Users browsing this forum: Google Adsense [Bot] and 78 guests
