by Stogie6 » Mon Mar 30, 2015 9:30 am
Good morning all Onex builders out there. I was completing the adjustments to the set screws on the aileron bell crank assembly (drawing ONX-W21) for both wings. In order to ensure zero "slop" when the ball and paddle mate, you adjust the 5/16 - 18 thread set screw accordingly. My issue is when it is all said and done, I have zero thread visible on the back nylon nut. For that matter, only about a third of the screw is engaged with the nut. I would like to see at least two threads projecting out, but I am not able to get this to happen. I built per plans - followed all details, etc. So, long story short - does anybody know of a supplier that has a longer set screw (1 1/4 inch or better) that I can replace the original set screw with? I am continuing my search on the internet, but thought I would ask. I may have to make one (actually - 4)!
Thanks for the input.
David F. Jones
Memphis (Mud Island), TN
Aerovee powered Onex
N153TD
Based at KAWM and in the midst of Phase 1
