Wing rib flanges
Wing rib flanges
Postby Sonex1517 » Sun Nov 20, 2011 3:03 pm
For anyone who has used the Sonex pre-built wing ribs, how much straightening did you have to do to the flanges? My brother is building an RV and made the tool in these photos - just curious if I will need one. I began to smooth the wing ribs a few minutes ago and noticed the flanges are definitely not at a 90 degree angle, but do not know enough about how the wings go together to know how this affects things.
I'd appreciate some input from those that have been there and done that.
Chicagoland
Aerovee/taildragger
Working on the tail
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Re: Wing rib flanges
Postby N111YX » Sun Nov 20, 2011 3:33 pm
I would just tweak them with my fingers, Robbie.
The bending device seems like overkill but I have never built an RV...:)
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby MichaelFarley56 » Sun Nov 20, 2011 3:52 pm
I'm 100% with Kip on this. If mine needed any adjusting at all, it was very little and done by hand. My rib prep was to make sure all edges and lightning holes were smooth with sandpaper, mark flange centerlines with a sharpie, and then start putting them on the spar. Most of the prep time was spent riveting the doublers in place on the several ribs closest to the wing root.
I never had any issues with the wing skins not being flat on the rib flanges, so I would also say that RV flange tool is way overkill.
Waiex #0056 - N569KM (sold)
Onex #245
Wing rib flanges
Postby Sonex1517 » Sun Nov 20, 2011 4:05 pm
Thanks guys - smoothing the ribs now. I am using scothbrite pads and so far it comes out pretty nice.
Chicagoland
Aerovee/taildragger
Working on the tail
Aero Estates (T25)
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Return to Sonex
Users browsing this forum: flyguy0609, Google [Bot] and 18 guests
