MichaelFarley56 wrote:I believe AN-6 is a 3/8" hole.
Sonex1517 wrote:I've been following this thread closely, as I am just now clamping my spars together to updrill.
I believe the question I have is directly relevant to this thread, so I will add it here instead of starting a new one.
I currently have the blocks at 3/16" and am mating the spars to updrill to 1/4" slowly in increments. I am set up to do this tomorrow morning.
Can someone please clarify what the final, last size of these holes will be when the wings are mounted and attached to the aircraft? Is the 1/4" the final size? I was told the final bolts are AN-6 and that would mean larger holes, obviously.
jmtraylor wrote:Nick, you're not the only one to do this. I followed the up drill by 32nds technique and it bit me on the right side. I've since purchased the bit Kerry recommended and remade the blocks. I have yet to build the courage up to try again so I can't comment on how the new bit works.
Mark
Users browsing this forum: No registered users and 62 guests
