gammaxy wrote:Did you try sawing through the adhesive with a piece of fishing line with knots tied in it?
fastj22 wrote:A heat gun will help release the adhesive.
I mounted mine on the spar and it's pretty stable. I also put a shoe on the fiberglass tail tip.
mike.smith wrote:fastj22 wrote:A heat gun will help release the adhesive.
What do you mean by a "shoe?" Any photos?
The plastic part that has the double sided tape. The GoPro arm clips into it. Its a common term in photography.
mike.smith wrote:The plastic part that has the double sided tape. The GoPro arm clips into it. Its a common term in photography.
So did you have an articulating arm from the shoe to get the camera level with the horizon?
fastj22 wrote:Yes, my camera came with the motor sport accessory kit, which has different lengths of arms and even a suction cup mount to I can stick inside the windshield.
Users browsing this forum: No registered users and 59 guests
