pchuckie wrote:How would one go about buying this partially built kit, finish it and register it themselves being the builder?
fastj22 wrote:Yes, in every factory supported configuration. The only way it might slip outside LSA parameters (max speed, stall speed) is if you install a high power non-factory approved engine or set the gross weight above the factory 1150 lbs. Or do something like install a constant speed prop or retractable gear.
Users browsing this forum: No registered users and 62 guests
