by MichaelFarley56 » Sat Mar 28, 2015 6:36 pm
The only applicable rules in this case are found in your Operating Limitations which specify where your Phase 1 testing must occur. As long as you stay in your test area you can do whatever you'd like.
For obvious reasons, it's probably not a good idea to venture far from your home base until you're confident in the airframe and engine's reliability. How long this ultimately takes will be up to you. I've heard of some people needing only 3-4 flights before they venture out while others stay overhead for 10 or more hours. For me personally, I generally stayed over the airport for the first 7-8 hours then stayed within visual sight (5 miles away or less) until I had nearly 20 hours on the airplane. That's what I was comfortable with!
Best of luck Dana! How's the airplane behaving?
Waiex #0056 - N569KM (sold)
Onex #245
