A larger instrument panel option
Postby GWMotley » Thu Mar 12, 2015 9:41 pm
Hello group,
When I built my Sonex I knew I wanted more real estate for switches and other things. Besides, what pilot doesn't like switches to play with? So I added a sub panel. This did require shortening the control sticks by about an inch or two. Still, I have plenty of stick to yank and bank like any true Sonex pilot. :D True, it does make it much more difficult to crawl under the panel for wiring issues. This winter, while down for other carb maintenance, I convinced my self to pull the windshield and begin designing a new larger instrument panel. Now I can mount a full sized Ipad right in the center! No more hanging bits and pieces of stuff around the glare shield. The panel is two inches taller than stock, but the overall surface area is much larger. Now, I can remove the subpanel, or the panel, or the top part of the glare shield to access any wires without having to break my back. This also decreases the cost of my chiropractic visits. The new panel size does not obstruct any view over the nose either. So, I thought I would provide a link to pictures for any who might be interested. Have fun flying.
Pictures are located here http://postimg.org/gallery/grsgfqv8/
Gary Motley
Sonex 1155
MGL/ipad panel
First Flight 08/2011
About 670 hours on this plane
GWMotley
Postby Sonex1517 » Thu Mar 12, 2015 10:25 pm
Nice!
Chicagoland
N1517S reserved
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Re: A larger instrument panel option
Postby DCASonex » Fri Mar 13, 2015 8:38 am
The bottom channel I added was only 1-3/4" deep, just big enough to mount standard circuit breakers, did not have to shorten the stick. Every fraction of an inch between seat and bottom of panel is critical when need arises to get under there. A large EFIS that mounts with just a couple of screws leaves a big hole for access behind panel eliminating much but not all of the need to crawl under under. Since panel is an integral structural part of the Sonex air frame, I also added additional structure when bisecting my panel with a large EFIS. Have drawings on that if anyone looking for ideas
DCASonex
Postby avee8r » Fri Mar 13, 2015 10:09 am
That's some panel alright!
Me? I prefer large size, full color, gyroscopically stabilized, horizon with real time, full view weather. Both are easily adjusted by your choice of inputs, already in the kit from Sonex. There's no consideration about ease of entry or exit and neither ever need updating.
Happy Landings
John
N50NX
avee8r
Users browsing this forum: Google [Bot] and 92 guests
