Sonex1517 wrote:http://www.sonexaircraft.com/documents/instruction_sheets/Upholstery_Install.pdf
Did you get this?
Chicagoland
N1517S reserved
N111YX wrote:Michael, the interior is a "cut to fit" project. I made about 4 different mods to mine using a local upholstery guy. He would cut, snip, and sew a mod for about $10 or $20. He also sewed in velcro strips to the baggage sling perimeter and I used the stringers and bulkheads for the opposite velcro. It 's more than adequate to hold the loads....
wlarson861 wrote:I attached the baggage sling with sheet metal screws and finishing washers. For the trim lever i cut a hole in the plastic backer and cut the leather in an X so I cold pull the tabs to the back and attached with contact cement. Made a nice edge around the hole. the side walls were attached with Velcro to a tab on the upper longeron like the photo in the instruction sheet (see above post for link)
Users browsing this forum: No registered users and 79 guests
