I voted for the last option because it was the only choice for someone who isn’t running the Aeroinjector after trying it.. but I don’t like the wording and wish there were one more option. I would describe my opinion as:
“The AeroCarb/AeroInjector is not the right choice for my mission and have chosen to go a different rout.”
I don’t hate the AeroInjector and think the wording of that option is just too strong.. but I have decided not to go with it.
I flew Waiex #142 with an AeroInjector twice; on my first two flights. To keep a long story short, I had two issues with my setup:
1-I could not develop full power
2-I did notice burps and power hesitations
For that reason I am converting over to a Rotec TBI MKII, with a pressurized fuel system. If my mission was different; say only local flights in part of the country where the seasonal weather changes were not that significant and I wasn’t interested in tweaking performance, the AeroInjector may be the carb for me. But the reality of my mission is that I need the TBI to perform reliably at sea level and 8000 DA elevations on a regular basis - on the same day, I live in one of the hottest, most miserable climate areas of the country, and yet hangar the airplane where it snows during the winter, and I don’t particularly find the adjustments to the AeroInjector to an easy nor a pleasant job and don’t want to do it multiple times per year.
For the more detailed version of the story:I really like the simplicity of the AeroInjector, and had high hopes that I would get it to run my Jabiru 3300 well. The initial setup during ground runs prior to first flight seemed too easy – I just threw the #3 needle in there and followed the instructions in the manual, and the engine lit up and came to life without issue on the first try. It would idle quite well, and I had no indication that the engine wanted to do anything other than continue running between 700-1000 rpm. I was able to achieve the specified ground static RPM (I got somewhere between 2900 and 3000 RPM on the ground), and response to the fastest throttle inputs I could give it seemed smooth and hesitation free. “Hard idle” throws after full throttle runs seemed smooth as well. This was all on the initial setting! The one gripe I had during this phase was that I was not able to get it set to hold a good idle RPM tolerance with the idle screw.. when I thought I had it set perfectly to about 800-850, it would tend to fluctuate by about 150 RPM or so despite my best efforts, but this didn’t seem that bad. I did note that the stated procedure in the manual to “set so that full rich produces 90-100 F lower than peak EGT temps at full throttle” was an impossible task to do on the ground, as the Jabiru would hit its max ground running CHT temp limit within about 15 seconds of full power application.. and the EGT’s had not settled out by that point – so I could never really perform this test. I tried it twice to no avail, and also tried a build up approach of trying to get something out of half throttle, ¾ throttle etc; but then got too worried about damaging something and thought it best to just see how it ran in the air and get the data point then. It was running, and refused to quit no matter what I did to it, so I thought it was time to go fly.
On first flight, my initial climb rate was much less than I thought it should have been, only about 800 fpm. I quickly realized that the source of that issue was from the lack of RPM that I was developing, only about 2800 or so and definitely less than I had been able to achieve statically on the ground only a few days prior which I found odd. I elected to continue the flight, as the engine was still running smooth and again, didn’t feel like it was about to die at all. Once I got to altitude after my first climb out I tried the mixture knob, and sure enough as I pulled it back the RPM did increase, but EGT temps went screaming up through the roof so I stopped and pushed it back in. I continued the rest of the flight like that and everything went fine, temps stayed in the green, had no indication that the engine was about to quit (even on final when I pulled hard idle), but I never did get to full power.
I killed one weekend after that flight trying to adjust the AeroInjector. It was apparent from the rise in EGT, fuel flow numbers (compared to the “typical” values in the Jab manual), and lack of power that on first flight that I was running much too rich. As soon as I tried to adjust for a leaner setting, the engine simply wouldn’t run. I tried these adjustments several times, and for the most part got very consistent results: 1/8 of a turn appeared to make no change, and after ¼ of a turn (lean) the engine would not start at idle like it used to. I could start it at, say 1/3rd ish throttle but it would immediately die when brought back to idle. It was disconcerting to me that the adjustment was this sensitive, because of the slop (free-play) in the needle setting is easily 1/8th of a turn’s worth (if not more). It is possible that I was not as precise as I thought with my adjustments during tightening, however I consider myself to be reasonably mechanically inclined and tried my best not to have it drift while tightening. After 10 hours of work, I ended up with a setting almost where I originally was to begin with. I tried to be a tad on the lean side (somewhere between 1/16th and 1/8th leaner, maybe). The thought I had walking away from this exercise was that if it truly was this sensitive and finicky, maybe I would get lucky and nail it – but I certainly didn’t want to have to do this on a regular basis. I was also a bit disgruntled because I had just put 15-20 or so startup cycles on my brand new, not broken in $19k engine in an attempt to get something that would let me develop full power.. which I needed to break in the engine!
All of the fuel flow data from the first flight. The black line being to the left of the red line indicates that my fuel flow was higher than what Jabiru defines as "typical".On flight two I saw largely no improvement in the amount of power that I could develop. Temps were still in the green, but as soon as I tried to lean out the mixture EGT’s again went soaring above the limits almost immediately, the engine began to run rough, and I wasn't close to the RPM that I was hoping for. On this flight I also experienced my first “Burps”, which seemed to happen randomly on several occasions. In addition there was at least one time where I advanced the throttle in flight and got a very sluggish response (first time I had experienced that). It was a good deal warmer (at least 20 F) on the day of flight 2 compared to flight 1 which probably contributed to vapor bubbles forming.. but I have a high quality, very insulated, continuously up-sloping, short-as-possible fuel line running directly from the gascolator to the AeroInjector, so the only thing I could probably do to make it any better would be to blast tube or remove the gascolator. The burps weren’t bad, didn’t feel like the engine was about to die.. but it did put thoughts in my head like “well at least I am right over the field right now”. I also live in a mountainous area (Mojave, CA) and will frequently find myself out of glide range to an airport and don’t want to put myself in the situation where those thoughts come into my head – if I can avoid it.
Shown here is the leaning out experiment that I performed on flight #2. As the data shows, EGT's increase by approximately 200F, go over limits, without much gain in RPM (only about ~75). The large RPM drop is what I attribute to roughness, well before the engine developed full power.Somewhat unrelated to all of this is the fact that I also haven’t passed a fuel-flow test on the ground yet. The Jab needs 10 GPH and the thumb rule states 1.5 times the max burn rate of the engine is what you should have. I can only get 12 GPH at about half fuel, and it drops off to about 9.5 GPH on the last gallon or so. My fuel system is: TANK - BALL VALVE - RED CUBE - 3/8” HARD LINE – GASCOLATOR - 3/8” FLEX LINE – AEROINJECTOR. Pretty simple. I could remove the red cube fuel flow transducer and maybe the flow under gravity feed alone would improve enough to pass this test – but I am not willing to do that because I nerd out on flight test data and I like the situational feedback that a fuel flow indication provides me in flight. In order to mitigate the burps, and provide the fuel flow the Jab needs for full power in any situation, my only options are to nix the gascolator AND red cube (and hope for the best), or to add a fuel pump. I don’t want to see what happens when I feed the AeroInjector with an unregulated fuel pump.. and by the time I add a regulator? Why not just go with the Rotec? By that point I have destroyed the AeroInjector’s main advantage of being the “simplest” solution.
I have read almost unanimous reports from everyone who has run both that allude to the Rotec TBI bringing high EGT’s under control. Best theory I have right now would be do the inarguably better fuel atomization that the Rotec gives over the AeroInjector providing a more efficient charge for the engine to burn quickly in the cylinders, and not as it is leaving the exhaust valve and passing the EGT probes. But who knows. If it works, I'll be happy.
Right now I feel painted into a 4 dimensional corner of being not able to lean the needle due to inconsistent running at the low end, therefor being quite rich at the high end and not being able to lean out due to EGT concerns and/or rough running, seeing evidence of vapor form in the fuel lines and not being willing to remove the only “unnecessary” restriction in my flow path to get the gravity feed to work. Add to this the concern of screwing up my brand new engine for not breaking it in properly as I am two flights deep and have not been able to develop full power yet. Each one of these concerns points me in the direction of a different fuel system setup, for which I am now one week into the modification process.
The new fuel system will be:
TANK – BALL VALVE – 40 MICRON FILTER – 3/8” HARD LINE – GASCOLATOR – 3/8” FLEX LINE – ELECTRIC PUMP - 3/8” FLEX LINE – ENGINE PUMP - 3/8” FLEX LINE – RED CUBE – ROTEC TBI MKII
My optimism is high, but I will report back with the results good or bad.
