by kevin814 » Wed Mar 11, 2015 6:32 pm
Don,
My center stick Sonex also has a two inch extension under the dash. When I fly in the center I have enough leg room, but when I fly left seat my knees hit the dash and it is very difficult to work the rudder pedals unless I remove the padded backrest from the seat. My plane doesn't use the lowered seat mod, and this could be a factor. I'm 6'2 with a 34 inseam. If your legs are a little shorter I don't think you will have a problem. It IS nice having the additional dash space.
My dash and the extension are riveted with the stainless rivets. I wish it was set up as others have done with screws or hinges. If I ever have to remove the panel or fuel tank my installation will become a real hassle. Some have said that stainless rivets are needed for structural rigidity, but I have never heard of a problem from people who have used screws, hinges, or even aluminum (easily drilled out) rivets.
Kevin K.
Cincinnati
Sonex 130 Taildragger, Jab 3300 w/Rotec TBI, 6" tailwheel,
