by mike.smith » Sat Feb 21, 2015 6:24 pm
The question is just simply how much do you trust your engine. That goes for any engine. I have 70+ hours on my AeroVee and I will admit I'm still a little nervous, but not because of the design or engineering. It's proven; it works. I'm a little nervous because "I" built it! After scratch building my Sonex I have faith that I can learn to do new things, but nobody is perfect, and you can't pre-flight the insides of your engine before you fly (I do do oil analysis at each oil change). So I am cautiously optimistic about my engine. I do plan to start flying longer trips this spring, and out to OSH this July.
But to put that in perspective, I have 400 hours behind Continentals and Lycomings. I have a tremendous number of night flying hours. I flew a LOT of single engine night flights, and even night IFR in the clouds in those single engine airplanes. But I have a family and many responsibilities that I didn't have back then. So although I may still fly a little single engine night, I will have to give it a long hard look, and ask if I really need to before I do. And that has nothing to do with the AeroVee. To me it is just as much a risk to fly those Continentals and Lycomings at night.
So to answer the original question, I personally would weigh my AeroVee and those Continentals and Lycomings equally in making the decision to fly over the Sierras.
As for the AeroCarb, it is what it is. For the majority of us it works perfectly well if you follow the instructions and take the time to dial it in. For some that takes longer than others. I imagine the tolerances on the AC and its needles is not down to the 1,000th of an inch, and so no two are exactly alike. Again, that's just the nature of the beast. If you don't like the thought of that, it's perfectly fine to use a carb you feel better about. Make yourself feel happy and safe. I spent a good bit of time fiddling with one needle, when I should have tried another needle sooner than I did. Once I got it dialed in, that was it. Unless you change something else on the engine, or the weather changes drastically, you should not have any issues with it. I dialed in my AeroVee back in Aug/Sept when the weather was hot and humid. I have not made any changes to the carb since then, and I've been flying in temps around 15 F. I make some different adjustments with the mixture knob, but nothing drastic, and it all works fine. I've been up to 10,000' MSL so far and it works just as well up there as down at sea level. That's just my experience. Your mileage may vary. :)
