Full Swivel Tailwheel
Postby kmacht » Fri Feb 20, 2015 2:11 pm
Anybody else seen or use the flyboy full swivel tailwheel for Sonex? I noticed it mentioned on one of the posts over on the Vans forums.
http://www.flyboyaccessories.com/product-p/1130.htm
I am too early in my flight testing to even think about making the switch but it is interesting.
#554
Re: Full Swivel Tailwheel
Postby Sonerai13 » Fri Feb 20, 2015 2:17 pm
In order to use a full-swivel tailwheel you need differential braking. Installing differential braking adds weight and complexity to a lightweight, simple airplane. You don't get something for nothing.
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Postby NWade » Fri Feb 20, 2015 3:03 pm
Sonerai13 wrote:In order to use a full-swivel tailwheel you need differential braking. Installing differential braking adds weight and complexity to a lightweight, simple airplane. You don't get something for nothing.
And I would point out that a swiveling tailwheel increases any aircraft's susceptibility to ground-looping, relative to the Sonex-style "direct-link" tailwheel.
The major benefit of a swiveling tailwheel is a tighter turning radius; but IMHO I have a hard time believing that this single benefit outweighs the added weight, cost, complexity, maintenance, and ground-loop possibilities. At least when it comes to the vast majority of pilots and airfields out there.
--Noel
NWade
Postby kmacht » Fri Feb 20, 2015 4:16 pm
I never said that I thought it was a good idea. It was just the first time I have heard of the product and was curious if anybody had tried it. There are a number of people out there with bigger tires, differential breaking, non-sonex provided tailwheels, extended forks, etc. It is an experimental aircraft after all.
#554
Postby Fastcapy » Fri Feb 20, 2015 4:43 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby DCASonex » Sat Feb 21, 2015 9:30 am
Thanks for the link, already have differential braking, but also have 6" tail wheel and no way I would go back to a 4". Idea is interesting enough to take another look at possibility of making 6" full swivel, but suspect it will raise tail too much.
David A
Postby radfordc » Sat Feb 21, 2015 10:10 am
DCASonex wrote:Idea is interesting enough to take another look at possibility of making 6" full swivel, but suspect it will raise tail too much.
I don't think raising the tail is a problem. The nose gear Sonex raises the tail pretty high.
radfordc
Postby mike.smith » Sat Feb 21, 2015 6:33 pm
I don't understand how it swivels AND steers. Seems like and oxymoron.
Postby fastj22 » Sat Feb 21, 2015 7:16 pm
mike.smith wrote:I don't understand how it swivels AND steers. Seems like and oxymoron.
It uses a spring loaded detent pin to capture the control arm to the pintle on the bracket. So you get direct steering until the force is sufficient to push in the detent and the wheel swings freely. It doesn't take much force to break the wheel out of the detent. But for slow speed taxiing its locked in. Most tailwheel planes are like this. Sonex is the outlier here.
I have differential brakes and if it would handle a 6 inch tailwheel, I'd probably spring for one. I sure would like to be able to turn on a dime at the end of a runway.
Postby Fastcapy » Sat Feb 21, 2015 7:30 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Users browsing this forum: Bing [Bot] and 45 guests
