Horizontal stabilizer tips ?
Postby Concorde » Wed Feb 11, 2015 3:03 pm
I am ready to rivet the Horizontal Stabilizer but since I had so much trouble fitting the cap on vertical , been thinking about doing the caps before riveting . Is there any reason not to do this ?
Note that I have not made the elevators yet .
Ben
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Re: Horizontal stabilizer tips ?
Postby ScottM-Sonex1629 » Wed Feb 11, 2015 3:23 pm
You can fit them before riveting the whole assembly, but you will either need to trim the elevator to fit the opening (not ideal) or install the elevator, fit the tips and tip ribs to the gap required, then rivet the tips in place.
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby Concorde » Thu Feb 12, 2015 10:09 am
Thanks Scott, I'm not sure if I understand you right about trimming the elevator . I thought as long as the elevator was the same length as horizontal the ends would lineup and if it needed a little of trimming it would be done at the elevator horn,am I wrong ?
It was such a headache fitting the cap on to the vertical that I want to avoid it if possible .
Ben
Ben
Sonex # 1684
Rotax 912uls
N379BS reserved.
Concorde
Postby gammaxy » Thu Feb 12, 2015 10:22 am
Concorde wrote:It was such a headache fitting the cap on to the vertical that I want to avoid it if possible.
Was it a pain because it was hard to stuff the tip around the aluminum rib at the tip? To solve this problem, I made my own tip ribs that were about 1/8" smaller all around.
Postby Concorde » Thu Feb 12, 2015 12:19 pm
Yes ? Also after pushing it in I couldn't get it out for final trimming and had to drill out several rivets.
Ben
Ben
Sonex # 1684
Rotax 912uls
N379BS reserved.
Concorde
Postby Lsaircraft » Sun Mar 22, 2015 11:41 am
Would you be able to line up the trailing edge of the tips with out the elevator installed?
Lsaircraft
