onex28 wrote:The tubing that came with my LRI from Value Engineering is 5/16 OD and 3/16 ID. Be sure to warm the tube end before pushing it straight on to the LRI fittings. Lubricant also helps.
David
Onex107 wrote:I built the same one from plans on the internet. It couldn't be simpler. Nothing to invent. The only big cost is the differential pressure gage for about $60. Once you have it calibrated for your stall speed you will be able to make slower landings with confidence. The hard part is drilling the two holes in the aluminum probe. I made it in two pieces of 1/4 inch and scored the hole center lines with a Dremmel cutoff wheel to help the drill stay centered. Worked the first time.
Dennis W. wrote:Same here. I built the probe from plans on the internet and hooked up to my MGL Enigma. So far works great. Used a piece of scrap AL stock to make the probe, two barbed fittings and some aquarium silicon air pump hose to hook it up....total cost about 5 bucks.
Users browsing this forum: No registered users and 44 guests
