by Mike53 » Wed Nov 02, 2011 9:46 am
- pi_16915.jpg (36.05 KiB) Viewed 4792 times
Just a suggestion but could you not machine the nut relief deeper. If it is made of aluminum you could use a plunge router with a straight plunge bit of the appropriate size.Remove enough material so that around the holes you have enough thread exposed.Actually it would probably be easier on a drill press with Brad point bit or a Forstner bit.
Mike
Antoine de Saint-Exupery
