Inflate tires without removing or modifying wheel pants?
Postby gammaxy » Fri Jan 30, 2015 12:47 am
Has anyone figured out a technique for inflating tires without removing the wheelpants or adding a hole to them?
I can easily reach the valve stem with my fingers and it seems with a right angle adapter or a low form-factor pump I should be able to inflate the tires.
Chris Madsen
Aerovee Sonex N256CM
Flying since September 2014
gammaxy
Re: Inflate tires without removing or modifying wheel pants?
Postby pepperdoug » Fri Jan 30, 2015 4:14 am
I use a flexible extension. It screws onto the valve stem and is about 6 inches long. Then inflate from the end of the extension. I think I got it from an auto parts store.
pepperdoug
Postby DCASonex » Fri Jan 30, 2015 9:29 am
I have 7/8" dia. holes drilled in my wheel pants, but found a pair of black snap plugs in my junk bin that just fit those holes, sit almost flush, Have not fallen out, and the black does not stand out on my dark blue wheel pants. Made custom inflation chuck to reach down those holes by taking guts from cheap angled type and installing into piece of 5/8" dia. brass drilled and tapped to suit.
David A. Sonex TD
DCASonex
Postby daleandee » Fri Jan 30, 2015 5:53 pm
daleandee
Users browsing this forum: No registered users and 56 guests
