MichaelFarley56 wrote:More important than the gaps, from what I remember, is the fit and tightness of those canopy hooks as you push the canopy slide forward (my terminology stinks, but I'm sure you know what I mean). When you insert the hooks through the upper longerons and through the phenolic block, then push the slide forward, you want to make sure there's no gap between those hooks and the phenolic blocks that would allow the canopy to move up and down. I recall filing away a little bit of material on those canopy hooks, but went very slowly to ensure there was a tight fit when the canopy was latched closed. As long as that's done, you'll have a nice, secure canopy.
JimCunningham wrote:On the subject of the strike plates, can anyone suggest a method for cutting the notch for the canopy latch in them? I can trace the notch on the longeron on them but am puzzled as to how I can cut the hole/notch in them.
Users browsing this forum: No registered users and 67 guests
