marsolgp wrote:Mike,
I got the same prop and ran into the same 'problems'… What I did was make small pins. Of course, the limiting factor is the diameter of the inner guide pin hole. So, I started with that diameter (don't have the figures with me). When that didn't get me much of an RPM increase, I went smaller. I made a bushing to go in the inner guide pin hole and that allowed me, of course to go smaller on the guide pin. I finally got down to a pin that pitched the prop pretty close to the Sensenich wood prop that I had on it. But then, the performance numbers were the same as that prop…go figure :lol: Oh, and the wood prop was smoother running.
It was fun to play around with it but it was a trade off, good RPM for T/O and cruise suffered. Not so good RPM on T/O and cruise speed went up…. It really was made for the Turbo, and that's where it shines. I now use the Number 2 pin and get about 2975 RPM on T/O at 40" MAP then phenomenal cruise speed (for an Aerovee). I haven't tried any other pins with the turbo yet. Once I'm comfortable with the turbo I'll start playing around with different pitches.
