fastj22 wrote:There's an extensive list on the Yahoo Sonex Builders forum in the files section.
Here's the link if it works
http://f1.grp.yahoofs.com/v1/QHKkTjILJa ... an2011.pdf
radfordc wrote:There are several factors to consider when setting gross weight. First is the load factor when pulling Gs as you already noted. Certainly a Sonex is strong enough. Next, you must consider the rate of climb. What RoC can you realistically get at a GW of 1250 (on a hot summer day) with the 3300? Finally, consider stall speed. What is the stall speed at 1250 compared to 1150? Also, if you intend to fly as a Sport Pilot, does the plane stall at 45 knots clean at 1250?
fastj22 wrote:Well,
go to Sonextalk on yahoo groups, go to files, its listed there.
Kai wrote:fastj22 wrote:Well,
It seems the whole Sonextalk Yahoo Group disappeared when Sonex discontinued the administration years ago. Anyhow, I am not successfull finding anything from those days.
Right now I am intensely looking for some info on tri gear Sonexes with Aerovee engines. How they were finished, what instrumentation was installed, and of course the resultant empty weight.
Kai
Users browsing this forum: No registered users and 46 guests
