Hello Fellow Builders -
I could use help and suggestions! After a nearly-flawless RH wing build, I started in on the LH wing assembly & skinning and ran into a problem. Below is an email I sent to Sonex Tech Support a few days ago. But since they're shut down for the Holidays I am tossing this out to all of you for ideas:
The wing-build has progressed well up until the point at which I have pilot-drilled the upper-aft skin to the LH wing. Before beginning (and again during progress), I made sure that the spars were twist-free, the wing & ribs were perfectly square, and that the distance from the main spar middle tooling-hole to the rear spar attachment point was set at 19", per the instructions. The upper aft wing-skin was set flush with the trailing edge of the rear spar upper flange along the entire length of the wing (and heavily clamped into place that way).
Pilot-drilling the ribs proceeded smoothly, and the ribs required almost no adjustment in order to get the centerline showing through the wing-skin's laser-drilled pilot holes. I checked the wing-skin overlap with the main spar and it appeared to be about 1/16" shy of meeting up with the forward edge of the main spar cap. This didn't bother me as my RH wing had an identical situation and turned out fine. So I began drilling through the wing-skin into main spar - working from the center of the wing both inboard and outboard. At the point I was about 85% done (last 2 rib bays at either end), I began to notice that the holes near the wing root were creeping towards the main-spar web, and the holes near the wingtip were creeping away from the main-spar web. At first I thought I was drilling at a different angle to the skin and that accounted for the difference; but as I neared completion and the skin was truly sitting flush against the spar caps I realized the problem: The wing skin was not quite square to the main spar!
At the tip of the wing, the upper aft skin extends forward of the upper spar cap by a few thousandths of an inch. At rib #5 (where the main-spar cap stops being parallel with the spar web) the upper aft wing skin is short of the cap by 1/16". And at the root of the wing, the upper aft skin is 'short' by about 3/32".
Here are photos showing the wing skin overlap of the LH main spar:
https://plus.google.com/photos/10396415 ... 8413352722https://plus.google.com/photos/10396415 ... 6774219794 Of course I discovered this while drilling holes in the wing spar - so if I have to re-do this I will need to build up a whole new main spar for the wing as the spar caps now have holes in them in the wrong locations... Heartsick, I've spent a couple of hours looking at the wing from every angle and taking every measurement I can. And from what I can tell, there is NO "twist" in the main spar or rear spar. There is also no problem with the wing ribs or variations in the distance between the main spar web and the rear spar web. Ribs are still square to the main spar, the 19" distance to the rear spar attachment is still good, etc.
Finally, we looked at the rear-spar in a different direction, and found what I believe to be the source of the problem: The outboard section of the rear spar (beyond the splice plate) was removed because I thought it was improperly dimensioned. But after removing it I discovered that it was correct all-along and re-riveted it to the splice plate. Somehow in doing this it got slightly out of square with the inboard section of the rear spar. Viewed with the wing in "flying position", the LH rear spar tip is 3/32" higher than the root end of the rear spar.
Here are photos of the rear spar misalignment:
https://plus.google.com/photos/10396415 ... 6310897650https://plus.google.com/photos/10396415 ... 6058358866 I assume that this misalignment effectively reduces the upper camber of the wing at the outboard tip, and that's allowing the skin to overlap the spar slightly further out at the tip. This is similar to a small amount of wing twist ("washout" as we would have called it back in my model-aircraft days). But I don't have an easy way to calculate the amount in degrees, to get an idea of how much of a concern this will be.
I know some Sonex builders wind up with a "heavy" wing and take care of balancing the aircraft by slightly drooping a flap or an aileron... Do you think this will be an acceptable work-around in my case, to correct this slight change in wing-shape at the outboard end?
Lastly: I'm mildly concerned about the bend in the rear spar causing the ailerons to bind due to having a non-straight hinge. Any thoughts or suggestions? Should I try to re-make the outboard end of the rear spar (to get it parallel with the rest of the rear spar), then re-drill the skin to it?
(Obviously, I'd have to accept that the trailing edge of the wing skin may not be flush with the trailing edge of the rear spar section)
Thanks in advance for any tips or ideas on how best to correct this,
--Noel Wade
Sonex #1339
(TD, Turbo, Center-Stick, Acro Ailerons)
