Canopy latch mod
Canopy latch mod
Postby Sonex825 » Mon Sep 29, 2014 11:21 pm
I like that tab you stick in there... I made mine a bit longer with an additional indent too but never use it since it just flexes and doesn't really stay. I might have to do something like this.
Eric M
Sonex825
Re: Canopy latch mod
Postby sport65 » Tue Dec 23, 2014 7:56 pm
I just purchased some 1" by 3" t6 from AS to make the mod,and it does not have
A radius on the inside of the angle. Is this acceptable to use? I figured if it was from AS,
It would have the radius like all the other angles for aircraft use.
Jeff
Sonex 1570, standard gear, matco independant brakes and wheels, aileron trim, MGL iefis, V6 radio, Uavionix adsb, stx-165 transponder, Jabiru 3300
Finished
Ponder Tx
sport65
Postby gammaxy » Tue Dec 23, 2014 9:30 pm
Building the latch might actually be easier without the radius. I had to grind my nylon washers to fit into the radiused corner and I even substituted a round tube for that part of the canopy frame (because the square tube in the plans didn't fit my radiused angle). I had the opposite problem--the angle I ordered had much more radius than shown in the plans.
I probably wouldn't hesitate to use your angle.
Chris Madsen
Aerovee Sonex N256CM
Flying since September 2014
gammaxy
Postby sport65 » Tue Dec 23, 2014 11:43 pm
Thanks Chris! I definitely like the no radius, I just want to make sure it is not a strength issue. All the angles I have used have the radius, so I'm confused as to why Aircraft Spruce sent me an angle without the radius. I have herd the Sonex won't fly without the canopy, so I want to be sure.
Jeff
Finished
Ponder Tx
sport65
Postby rizzz » Wed Dec 24, 2014 12:00 am
sport65 wrote:Thanks Chris! I definitely like the no radius, I just want to make sure it is not a strength issue. All the angles I have used have the radius, so I'm confused as to why Aircraft Spruce sent me an angle without the radius. I have herd the Sonex won't fly without the canopy, so I want to be sure.
I just finished my canopy and I can concur, an angle with no radius would have been easier. I ground away part of the radius with my Dremel tool to get the washers to fit.
That said, the 6061T6 aluminium angles usually all have the radius. The angles with no radius are usually a different grade. It probably does not matter for this part but just check what it is to make sure anyway.
rizzz
Postby sport65 » Mon Dec 29, 2014 4:02 pm
Well hope everyone had a great Christmas !! Thanks for the replies! Just got word from the Sonex tech
Gurus it is good to go. I tried to order from AS to avoid wondering about strength or compatibility issues, and still had them. So if you don't mind 3" instead of 4" angle to raise the canopy a little less, AS is good to go without the radius.
Thanks guys
Jeff
Finished
Ponder Tx
sport65
Users browsing this forum: Google [Bot] and 50 guests
