by Darick » Sun Dec 21, 2014 6:58 pm
My first thought when considering the MGL Velocity engine monitor, is that you can't monitor all CHT/EGT since it only has four inputs. It seems many folks use this set up for the AeroVee so it must not be a big concern. A way around this is to also include an extra gauge, the MGL TC-1, which would give you an extra four temperature monitoring channels. What do you think...am I being overly concerned about getting all four EGTs and CHTs?
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
