Make Your Own Air/Oil Separator
Postby rizzz » Sun Dec 21, 2014 6:56 pm
I decided to make my own oil/air separator.
Pretty much as per the instructions here:
http://www.y8s.com/celica_gone/air-oil/
Some pictures:
Once I get to the flying stage I’ll let you all know if it works or not.
rizzz
Re: Make Your Own Air/Oil Separator
Postby Brett » Sun Dec 21, 2014 7:19 pm
I made one similar out of pvc plumbing as well. It worked just fine, but not long after discoloured due to heat from the exhaust. I had heat wrap on the exhausts already. It may have been ok but I removed it and purchased and aluminum one from a automotive shop. The sonex factory one was too large for my engine bay.
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Postby jwd3ca » Mon Dec 22, 2014 9:33 am
I used a $5.00 anodised aluminum water bottle along with a bicycle water bottle holder to mount it. Works beautifully if you're not interested in returning anything back to the engine. I'd include a pic or two, but get "Sorry, the board attachment quota has been reached." when I try.
jwd3ca
Postby rizzz » Mon Dec 22, 2014 6:28 pm
jwd3ca wrote:I used a $5.00 anodised aluminum water bottle along with a bicycle water bottle holder to mount it. Works beautifully if you're not interested in returning anything back to the engine. I'd include a pic or two, but get "Sorry, the board attachment quota has been reached." when I try.
You can't upload images to the site directly anymore, use postimage.org or something like that to upload the image, then put the link here within 2 "img" tags, see explanation here: viewtopic.php?f=21&t=107
rizzz
Postby rizzz » Mon Dec 22, 2014 6:29 pm
Some pictures of the installation:
rizzz
Postby mike.smith » Mon Dec 22, 2014 8:49 pm
I used that same web site as inspiration, but configured mine a little differently.
http://www.mykitlog.com/users/display_l ... 947&row=35
http://www.mykitlog.com/users/display_l ... 130&row=34
http://www.mykitlog.com/users/display_l ... 492&row=26
I was still getting enough oil vapor coming out the relief tube (and running across the bottom of the fuselage) that I finally put in a catch can instead of dumping it overboard. It's primarily vapor, so there isn't much that accumulates in the catch can.
Users browsing this forum: No registered users and 78 guests
