by marsolgp » Thu Dec 18, 2014 10:38 pm
Waiex 188 is now officially powered by a TurboVee. Installation completed yesterday and a quick run was done to check for leaks, etc. Needs a little carb adjustment and then high power run, but that will have to wait till weather clears….snow on ground. Tried to upload a couple photos but they were too big…. I'll try figure it out tomorrow.
It's a nice kit with a few small issues, but all in all went rather well. The exhaust system fit will try your patience, but stick with it, it will fit. My turbo needed both the compressor and turbine to be reclocked… not a big deal, loosen a couple bolts on the turbine side and rotate to desired position. The compressor side is held together with a big circlip, you'll need snap ring pliers and just compress it slightly and rotate housing, do not need to remove circlip. The turbo support bracket lower hole is too small for the bolt, up drill before you try installing the bolt…. I played with it for 20 minutes before I realized hole too small. The fittings that are to be installed in the new oil pump (P/N 991955ERL) have o-rings on them, they're not needed and could possibly fall off and fowl the pump…. remove them before installation. If you have the Sonex oil separator you'll need to purchase fittings to drain back into sump, they weren't included in my kit, but I had spares sitting around. And finally, I had a small issue with the LH intake elbow that goes from intake center section and manifold in LH head. I ended up making my own new one from the removed "Y" intake….. Tech at Aeroconversions is working on it. This may have just been a one off and only affected me, but be aware there could be a problem with fit. Good Luck to all you new Turbo Kit Installers.
G. Marsolais
Waiex w/Turbo Aerovee
MGL Xtreme EFIS & EMS
A/P, iFly720 w/ADS-B
