Direct C51 wrote:I am amazed at how bad that corrosion is after just 1 year. Is that corrosion under the rivets as well? The picture makes it look like it is, especially the top one in the picture. Maybe I should rethink my corrosion protection plan, or lack thereof.
rizzz wrote:Look up galvanic corrosion. Happens when you have 2 dissimilar metals in contact with each other.
Onex wrote:Corrosion of dissimilar metals requires three things. Two different chemistry metals and an electrolyte (water). The more noble material, aluminum, is the anode and the less noble, stainless rivets (which contain some iron), the cathode. The difference in potential sets up a very weak current from the anode to the cathode which carries some of the anode with it. The potential between aluminum and stainless steel is very low due to the high amount of alloy, and low per cent of iron, in the stainless.
In your case you said the steel was rusty. Rust is 100% iron oxide, FE3O4, and is caused by the oxygen in water combining with the iron in the steel. So you had all the worst conditions present. Iron oxide, with a high concentration of iron and oxygen, and a high potential, and water to make the circuit complete. The potential between the stainless rivets and 6063 is not high enough to be concerned about, unless you live next to the ocean, then you should consider painting. Salt water is a better electrolyte.
Onex 107
Users browsing this forum: No registered users and 64 guests
