by n982sx » Mon Dec 15, 2014 10:34 am
Aldo,
While a five year old battery may be near its end of life, I don't think a new battery is going to help you much. The permanent magnet alternator on an Aerovee only deliver enough amps to recharge at higher RPM's. I collect the data stream from my Enigma for all my flights and it shows a pretty consistent voltage curve during my flights.
The data show that it takes at least 45 minutes to recharge the battery with RPM's in the 3000 range. If you have a voltage display available in flight, I would track the change in voltage over the course of your flights. You would like to see the voltage come up to at least 14 volts (assuming your measuring device is calibrated, about 1 volt increase from the start of the flight if not). If you get up to around that number you know your battery is mostly finished filling up.
My time listed above is with an Aerovee 2.0 and the 20 amp alternator, if you have the 10 amp alternator your recharge time will probably be longer.
Specific things you could try. Do one flight at normal cruise RPM's measuring your voltage, and do another at WOT. You will get a quicker rise at 3300 to 3400 RPM than you will at 3000 to 3100. Also, while monitoring voltage in cruise, turn off your secondary ignition for one flight during cruise and see if that makes a difference (there are a few Aerovee flyers who regularly fly this way). Depending on what electrical devices you have in your plane, it might be the highest drawing device you have. Lights, especially non LED lights would be the other high draws.
The PC625 will take all the amps you can throw at it with no worries. So turn off any other high current devices that you don't require and it will gobble up those amps. If none of this helps, and I suspect it won't help much, and you have access to power when your aircraft is at its home base, hook it up to a smart charger every night. Your battery will thank you and I'm sure you will have enough juice in the battery to make one remote start to come home.
