Aeroinjector/Aerovee fuel line
Postby Gripdana » Mon Dec 15, 2014 9:20 am
I have been looking at the Aircraft Spruce website for the fuel line. I am having trouble figuring out which line to get. The website is not so easy to search on at times. Does anyone have a part number or a better description I can use to search for the line?
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Re: Aeroinjector/Aerovee fuel line
Postby marsolgp » Mon Dec 15, 2014 12:37 pm
You could try Aeroquip 601 or go to Jegs.com for the -6 hose and fittings… cheaper and plenty good enough for gravity feed system. Or, if you are referring to tubing, then 5052-0 which is hard to bend or 3003-0 which is easier to bend…. both will work in fuel system.
G. Marsolais
Waiex w/Turbo Aerovee
MGL Xtreme EFIS & EMS
A/P, iFly720 w/ADS-B
marsolgp
Users browsing this forum: Bing [Bot], Google Feedfetcher and 6 guests
