Rotec TBI Setup
Rotec TBI Setup
Postby bkortens » Wed Oct 29, 2014 5:39 pm
I have a Rotec TBI on my Jab 3300 that I'm finally getting around to setting up. I am hoping to not re-invent the wheel installing it.
I originally had the Aero Injector installed and never got it to run well enough to be happy wtih it. I built the Sonex plans air shuttle box and I currently have the Sonex throttle quadrant installed.
I'm looking for advise on. carb heat set-ups, cables, air filters used, NACA vent used for intake? Any pictures of a set-up that is working well would be appreciated. I have a tailwheel but will be happy to look at anyone's set-up.
Thanks in advance.
Bill Kortens
Sonex 1114
bkortens
Re: Rotec TBI Setup
Postby Craig Hoskins » Mon Nov 03, 2014 8:00 pm
Bill,
I installed a Rotec TBI on my Sonex tri-gear 1537 and have over 30 hours on it now. I installed traditional vernier push-pull cables. I really like the accurate control of throttle & mixture. The air filter in the filter box is 4-in OD by 2-in thick. I have both carb heat & ram air through a damper to select which I want. The neat thing about the Rotec TBI is that it automatically adjusts for the increased ram air to maintain proper mixture. (Sonex recommends against ram-air with their AeroCarb TBI because it changes the mixture) My caution to you would be that the comments Rotec makes in their information is that you are responsible for the intake system to the engine to make sure equal mixture gets to each cylinder so they run balanced and not one rich and another lean. I had to build a new intake manifold to improve the balance since the spray bar is not symmetrical in the throttle body. I have two fuel pumps, but found out that it still runs fine from gravity from the main fuel tank. I'm very pleased with it's performance. I fly with much more confidence now. Good luck with your project. I posted some pictures for you under: Picture/Album, Sonex no. 1537 (Craig Hoskins)
Happy safe flying,
Craig Hoskins
Sonex 1537, Tri Gear, 145 hrs
GPAS 2276cc VW, Rotec 34-2 TBI, Prince P-tip
GRT Sport SX EFIS
Craig Hoskins
Re: Rotec TBI Setup
Postby allycol » Mon Dec 08, 2014 5:25 pm
Hi Craig
Good to hear your Rotec TB is working OK I personaly would not have any thing from Rotec on my aircraft read my post Rotec LCheads Danger.
The only thing I can say if you buy from Rotec dismantle it and inspect it carefully. Cheers Allycol
allycol
Re: Rotec TBI Setup
Postby Major4567 » Mon Dec 08, 2014 7:29 pm
Allycol
Who are you?
What country are you from?
What Sonex do you own?
What engine is in your Sonex?
You have spoken badly about Rotec before on the LCH thread. If you have had a bad experience with Rotec that's unfortunate. It would be helpful to have the above questions answered to as the validity of your comments on this site.
Here is an example.
Steve Stahl
Waiex N54YX
Jab 3300
Rotec LCH
Major4567
Re: Rotec TBI Setup
Postby marsolgp » Mon Dec 08, 2014 8:03 pm
Hey Steve, I asked him the same questions last week and he ignored me and started this new thread…… I guess he's entitled to his OPINION, just so as people understand it is opinion only.
G. Marsolais
Waiex w/Turbo Aerovee
MGL Xtreme EFIS & EMS
A/P, iFly720 w/ADS-B
marsolgp
Re: Rotec TBI Setup
Postby Major4567 » Mon Dec 08, 2014 8:08 pm
I remember.
Steve
Major4567
Re: Rotec TBI Setup
Postby chuckster » Tue Dec 09, 2014 12:40 am
Like that old song says, " believe half of what you see, and none of what you hear "
chuckster
Re: Rotec TBI Setup
Postby Brett » Tue Dec 09, 2014 6:13 am
The rotec tbi is working just fine on my aerovee. I'd say it's just someone with a big gripe with Rotec.
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Re: Rotec TBI Setup
Postby Pickleman » Tue Dec 09, 2014 3:04 pm
I have noticed that often a correlation exists between basic grammar skills and critical thinking skills. When someone fills their thread with run-on sentences to facilitate their attacks, it is usually best to discount their two cents worth.
:twisted:
Pickleman
Re: Rotec TBI Setup
Postby zipper » Tue Feb 03, 2015 8:39 pm
I have seen a picture of a rotec fuel regulator with a solenoid to depress the plunger instead of some cable operated lash up. I would like to use that idea and need to know what solenoid was used, etc. It seems like a great idea to me,
thanks….George Andre 8-)
zipper
Return to Jabiru
