by Bryan Cotton » Fri Dec 05, 2014 4:56 pm
Saw it happen on a different brand of ELT when I used to support avionics at Sikorsky in Elmira. One of the boffins set it off and initially NOAA called the ELT manufacturer who said that we bought it. Gave the position of the ELT factory.
I went on aircraft spruce and you will find a factory generated FAQ which states it uses the last GPS fix. Also gives a factory email address for other obscure questions.
Edit:
http://www.aircraftspruce.com/catalog/pdf/e04faq.pdf
by DCASonex » Sat Dec 06, 2014 10:01 am
NWade wrote:Bryan Cotton wrote:Noel,
I think you will find that the ELT will broadcast the last good GPS coordinate it had. That should get you pretty close to the accident.
Bryan - I would hope so, but the ACK website doesn't actually state this in the documentation I could find.
If I get a chance, I'll email the manufacturer this weekend and let everyone know what they say...
--Noel
That is the info I have as well, signals are constantly fed to the ELT. which uses latest when triggered, and for the record, same ACK ELT interfaces very nicely with GPS output from my GRT Sport SX
by Bryan Cotton » Sat Dec 06, 2014 10:49 am
You could also buy or recycle an old tech GPS, like a Garmin III or pilot III. Just needs a NEMA input.
