Flywheel bolts
Postby rbarber » Tue Sep 30, 2014 10:55 pm
Kai,
There were quite a few earlier 3300 that were only torqued to 18 ft lbs. Up to around SN 500- 600 I think. This of course falls under the "improper torque" category. Under the "faulty combustion" category, I can't help but wonder about the uneven fuel distribution that the intake/carb arrangement on the Jabiru. It is astounding how much a 5 degree rotation of the carb can bias the EGTs. And this would be easy to overlook.
The point is: "nothing wrong with them at all" should be perhaps "nothing found wrong with them". After all, something had to be different to cause them to fail. Given the complicated nature of this, not seeing all causes is not a surprise.
rbarber
Re: Flywheel bolts
Postby allycol » Wed Dec 03, 2014 6:32 pm
sonex1284 wrote:Can anyone (Rob?) figure out how to do this bolt replacement without pulling the engine? I'm not sure it's possible. I'm approaching 200 hours and it's a mild concern.
Mike
Jab have a boss i think you can buy for flywheel to redrill the extra dowl holes and you just remove the engine and flywheel. I think you would have to remove the rear seal casing not sure but I am sure you would not have to do a major strip. I was lucky mine 2200 was the first hydrolic lifter so the mod was done. I just done a major overhaul and reverted back to solid lifters all went well. allycol.Any one who wants info on solid lifters reply. Cheers
allycol
Re: Flywheel bolts
Postby Xenos29DN » Tue Dec 09, 2014 3:23 pm
Where does one get the flywheel attachment bolts and "hardened" washers? If using washers, do the bolts have to be slightly longer to account for the washer or is there enough thread there?
Dave
Xenos N29DN
Xenos29DN
Re: Flywheel bolts
Postby hickej » Wed Dec 10, 2014 10:45 am
Call Pete at Jabiru USA and he can get them for you or tell you exactly what you need. I just went to his engine seminar and he knows these engines Inside and out. On personal note, he is one of the good guys in aviation and deserves our support of his business. As the only remaining Jabiru dealer in the US in a tough economy we need to be rooting for him and the family business.
hickej
Return to Jabiru
