WIX-F11 question (Sonex or Waiex)
Postby Bryan Cotton » Mon Dec 01, 2014 11:53 pm
Hi all,
My forward tunnel zee has a pilot hole for the wing attach bolts through the forward wing mount angle. On the referenced page it shows no hole there yet. When do you drill that hole?
Postby Sonex1517 » Tue Dec 02, 2014 2:17 am
Bryan
While I am building a Sonex, my zee had that hole. I piloted it through and should not have done that.
If this hole is the same as on my matched hole kit, do not drill it through! I believe tech support would say the same but please verify with them.
(For what it is worth, my decision to use that as a pilot and drill through cost me dearly. I had to redo the wing rigging)
Chicagoland
N1517S reserved
Re: WIX-F11 question (Sonex or Waiex)
Postby Bryan Cotton » Tue Dec 02, 2014 8:16 am
Thanks Robbie! I had not drilled that hole yet. Sounds like I shouldn't!
Postby Rynoth » Tue Dec 02, 2014 8:42 am
Do NOT drill that hole. I ended up having to replace my right side fwd wing attach angle during rigging because I had drilled that hole. The actual hole location will be closer to the side panels.
Postby n502pd » Tue Dec 02, 2014 1:05 pm
OK, now I am worried! I am scratch building TD Sonex. Which exact hole are you fellows talking about? I am comming up on wing rigging this spring and dont want to make what appears to be a mistake , if I havnt made it already. I am not in front of my plans yet today, but could there be a better explaination of which hole is being discussed? I "think" I understand which one, but...well.. I am nearing 70 years old and I have to make sure of lots more stuff before I run off in any partictular direction. Ha Ha !! thanks!! :?
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Postby ScottM-Sonex1629 » Tue Dec 02, 2014 1:39 pm
Bryan-
I agree 100% with Robbie and Ryan.
Don't up drill or transfer that hole to the forward wing attach angles.
Joe - if you are scratch building this hole will not be in your forward Z-Tunnel. This is a remnant hole from the CNC process Sonex is using to jig the part or something along those lines. Te hole is a mistake in their manufacturing process and as others have testified would lead you to drilling it out when in fact it shouldn't be.
I caught my error early enough and was able to make my parts work (PM me if anyone wants to go into this deeper)...
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby Rynoth » Tue Dec 02, 2014 2:16 pm
It's the small hole at the edge of my larger wing bolt hole that effectively ruined the part. The only reason you might put it there is if you pilot drill every single CNC hole in the forward tunnel Z provided in the kit. Since the hole isn't in the plans, I don't think it's an issue for scratch builders. These pics are of the right forward wing attach angle.
This pic is after I drilled out the rivets and removed the angle from the fuselage.
Thankfully my left side was ok.
Postby Sonex1517 » Tue Dec 02, 2014 7:15 pm
Those photos look painfully familiar.
Joe - not an issue you should see.
Postby n502pd » Wed Dec 03, 2014 12:26 am
Thanks Scott and Robbie...Indeed, I did check and I have no hole there...on either side. I sure wish my parts looked like that!! I suspose if I had a CNC they could have?
Joe Nelsen
scratch built :D
Flying @81.7
n502pd
