Major4567 wrote:I'm using 100ll with decalin runup. No detonation. Runs smooth as silk.
Major4567 wrote:My LCH have been on for about 30 hours now. Head temps stay between 190-200 F. Head bolts have been checked periodically with no movement. I have had no problems with my Liquid cooled heads at all. I thought the workmanship was first rate. Factory support was always prompt, friendly, and informative. No leaks have been detected whether it be coolant or oil. I'm happy so far.
Steve Stahl
Waiex 054YX
Jab 3300
Major4567 wrote:Dale
The temp I quoted was for the coolant temps. My CHT under the exhaust plug Is from 275-350 F. According to Rotec, the coolant temp. Is more accurate as all six cylinders are being fed the same coolant at the same time. I'm using 100ll with decalin r to detonation. Runs smooth as silk.
Steve Stahl
Waiex 054YX
3300
Steve Stahl
Waiex 054YX
Jab 3300
kevin814 wrote:Hi, I am interested in buying these liquid cooled heads for my 3300. I have heard a lot of good things about them, and about Rotec.
Kevin
Users browsing this forum: No registered users and 24 guests
