tmobbs wrote: To make room for the eventual installation of the Turbo, I plan to use the top-mounted oil cooler. Kerry says there are as yet no drawings to enable me to do this, so if any one on the forum has installed the top mounted cooler in the Sonex standard cowling, I'd like to hear more.
Tim Mobbs
Sonex #1555 Aerovee #0672
Hi Tim,
As Bryan has pointed out, I have been flying my Waiex with the top mounted cooler for a year now. Overall I'm very happy with the setup and have had no issues. When you install the cooler, follow the AeroVee instructions on removing portions of the bottom flange so the cooler will fit over the cooler mount. Also, there is a flange on the "top" of the cooler (when mounted) on the forward/prop side that you will need to file away. This should give you sufficient clearance for the stock Sonex or Waiex cowling, but some individuals have needed to file a little extra off the outer housing for cowling clearance. The "tight" spot is where the cowling hinge is located so be ready to file the cooler or remove a hinge lug.
If you have any questions, please let me know!
