jgpainter2 wrote:Hi Mike. This is what I do to preheat my Sonex/Aerovee. Go to the Wolverine engine heater website, and note model 9.0,125 Watt round 3" heater. This unit sells for $60. Then, realize that VW made a sump plate WITHOUT a drain plug for their later (1970's ish) engines. This was to force lazy mechanics to clean the strainer when doing an oil change, as the whole plate had to be removed. True story.
dtwolcott wrote:Mike
Rather than a rheostat to limit the voltage I think you need a thermostat that measures the temperature at some point on the engine that turns the heater on and off based on a set temperature.
Don
Waiex 132
Users browsing this forum: No registered users and 57 guests
