Finished pulling the engine apart and there are a few things I am worried about:
1) The crank has some wear at the bearing by the prop hub and some grooves on the actual prop hub presumably due to some extra slop in the bearing (next issue), though I am unsure what the hub must have rubbed on as the cowling is in good shape and being fiberglass should be softer than the hub is...
Better detail of the groove on the crank. The high and lows match the bearing inside surfaces:
2) There is excessive play (of course) in the bearing fit of something like .006"-.010" as detailed in this video:
http://jordanfuerst.com/Waiex/bearingPlay.mp4Surprisingly I do not believe that the case needs to be align bored, but I have found a shop about 30 minutes from my home that will do that for me. What is the appropriate measure to be taken with the crank?
3) I have a few burned valves as detailed here:
Obviously I will need to replace them but I am worried that there seems to be cracks between the valve seats:
and here:
For the record Sonex has been very responsive and I will assemble another email to them requesting advice. That being said, I have received a number of PMs for people wanting to know the final outcome and some that worry they are in the same boat, while I think the valve issue is separate from the end-play issue I figure I may as well keep the document going for the next Sonex owner that is doing his 1am search to see how much work he has ahead :lol:
I'm interested in suggestions for:
1) Fixing the crank (or must I replace it?) - Ideas on why this is the only bearing with issues? Oil supply problem?
2) Valves - Well, anything I should know?
3) Cracked valve seats? - The web seems split on if it's that big of a deal, with many saying to continue on as normal, or fix it, or replace it.... Personally I have never heard of a crack being acceptable till I looked into the VW websites.
4) Align bore even if the case seems to measure okay?
5) Anything else?
