kmacht wrote:Depending on how new this engine is it may be as simple as needing to pull the gland nut and re shim it or if it has a lot of hours on it with that much endplay you could have ruined the thrust bearing and likely damaged the case.
marsolgp wrote:Looks like crank was not shimmed correctly…. when you move the prop, have someone watch the flywheel. If it's moving too, then shimming will need to be checked. Crank end play should be between 0.003" and 0.006 per build manual. How many hours are on this Aerovee? Any oil leaks at flywheel seal?
kmacht wrote: That is way too much endplay. Depending on how new this engine is it may be as simple as needing to pull the gland nut and re shim it or if it has a lot of hours on it with that much endplay you could have ruined the thrust bearing and likely damaged the case. In either case I wouldn't fly it until you have it figured out.
..In other words, see if the crankshaft can be push-pulled long-wise through the case. If you can see/feel more than the tiniest motion (0.006"-- same feel as a normal tappet movement), the end-play is excessive, usually due to the bearing. If the bearing has been spun, you can NOT compensate by shimming more...
rizzz wrote:Excessive end play on a VW (not an aero engine in this case but it does not matter):..In other words, see if the crankshaft can be push-pulled long-wise through the case. If you can see/feel more than the tiniest motion (0.006"-- same feel as a normal tappet movement), the end-play is excessive, usually due to the bearing. If the bearing has been spun, you can NOT compensate by shimming more...
Read the full story here:
http://www.vw-resource.com/endplay.html
From what I can see in the video, I fear you might have a similar issue.
Users browsing this forum: Google Adsense [Bot] and 90 guests
