Updrilling Mated Spars
Postby Gunther » Mon Oct 20, 2014 8:32 pm
Hello to all. I have clamped the spars together to updrill the spar blocks from 3/16" to 1/4" and the three alignment holes from 3/32" to 1/4". Can the updrilling be done by hand or should I use my drill press? Should I up up drill in small steps such as 1/64" or 1/32"? Any special considerations or cautions that I should watch for?
Thank you,
Gunther
Tri-gear Sonex, Turbo AeroVee, dual controls, 70% complete
Gunther
Postby Sonex1517 » Mon Oct 20, 2014 8:50 pm
Hi Gunther
As always, Sonex tech support is the one to ask.
My personal experience is to updrill directly from 3/16" to 1/4" with the spars mated and clamped. Be certain the drill bit enters at a perfect 90 degree angle. (I know how important it is because I failed to do this properly)
Once this is complete, using a high quality piloted bit to go directly up to 3/8" is the recommended process. Several specific piloted bits have been discussed in recent threads.
There are numerous techniques that work, so you need to find what works best for you - the factory strongly recommends following the plans. Others have different methods that also work but do not follow the recommended process. There are links to those methods in other threads.
I just finished my wing rigging yesterday. It took me three tries but I got it done!
The Sonex Foundation offers a tool loan program if you need a piloted bit.
Chicagoland
N1517S reserved
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Gunther
I should have added I was referring to the wing block holes to updrill directly.
Chicagoland
N1517S reserved
Aero Estates (T25)
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Re: Updrilling Mated Spars
Postby rizzz » Mon Oct 20, 2014 10:28 pm
I updrilled from 3/16 to 1/4 directly on a drill press.
My little drill press did not have the stroke to push all the way through so I borrowed one from a friend, it was bigger than mine but still did not reach all the way through.
I resolved the issue by inserting the drill bit initially as far as I could in the drill, install the mated spars perfectly perpendicular to the drill bit on the drill press, drill as far as I could into the blocks/spars, retract, loosen the drill bit and now move it as far out of the chuck as possible and tighten again, then drill through the last bit of material. Worked great.
Personally I'd be a little hesitant to do this by hand, I would just be too scared to stuff it up,
But, I've seen it done so I know it works, (here for example: http://www.synelec.com.au/sonex/showcon ... ings/spars, scroll all the way to the end of the page),
rizzz
Users browsing this forum: Google [Bot] and 74 guests
