rbarber wrote:I have TO brakes and matco master cylinders. After 637 hours, here is what I have learned about them: shortly after installing new pads, you will have to remove a spacer washer to keep the gap between the disc and pads correct. Otherwise you will have to pump them quite a bit to get full function. Also, they will get hot quick and take a while to cool off. If the gap between the pads and rotor is at the minimum, they will stick a bit when hot, and have diminished maximum braking power. They still work, just not as well as when cold. I have met several folks who have them, but didn't know how to adjust the gap. If you don't adjust the gap, you will get poor performance.
sonex293 wrote:I had no problem with holding power of the TO brakes with my Jab3300. I could do a full power run-up and it wouldn't move an inch... I was able to latch the brake handle on my flaps motor for a nice parking brake.
Michaelfastj22 wrote:I also have TOB brakes. I switched from Great Plains disc brakes when I converted to a tail dragger. The GP brakes were so strong, I had to be careful not to lock up a tire on landing. I went with the TOBs because I also bought the TOB gear legs. They mate nicely. I also didn't like the squeaking I was getting from the GPs while taxiing.
The TOBs barely hold during runup at full throttle. They work fine during taxiing and light braking on landing and are smooth and quiet. I'd like more holding power, but they seem to be fine for me right now. The GPs sit in a box waiting for the coach to give them a second chance.
Bruce593SX wrote:Email Tracy off the email at the bottom of his web page, he responded to me on a Saturday within 2hours with the instructions attached
rbarber wrote:Oops! I really should not post from my cell phone...
OK, there are three main pieces of the wheel unit: the actuator, the rotor, or disc, and the outer plate. The outer plate is held in place with 3-4 BHCS screws. These screws pass through the plate, a tube, and the washers in question. The inside surface of the rotor rubs against these tubes. So the washers space the tubes out, moving the outer plate out. The more washers, the more brake pad space is available.
This is a bit awkward to do. A lot of parts to hold in place at once. I found it easier to wire tie the pads together to keep everything aligned, you may find an easier way.
Rob.
Users browsing this forum: No registered users and 67 guests
