142YX wrote:WOW we must be neck and neck.. i just worked on this very assembly today as well!
Unless you are trying to make a showplane.. shave some metal off of it and move on, thats my advice. I screwed up positioned the member right above this one an 1/8th too low on the right side, had to make a similar modification (to the top of the same bracket). These metal bits only comunicate load between each other in shear.. and only at the location of the fasteners. So my rule of thumb is unless it affects a revit/bolt position, makes some other assembly impossible, or is so ugly that i can never live with myself.. i move on with my misstakes.
N111YX wrote:Andy, take a few thousadths off the seatbelt angle and carry on. You could probably take 1/4 inch off and still have a valid structure...and a showplane...:)
Users browsing this forum: Google [Bot] and 26 guests
