Tracy O'Brien brakes not braking
Postby JohnF » Mon Sep 29, 2014 10:43 am
I have a flying Sonex (277 hrs TT) that I purchased to facilitate transition training while I build mine. I just started flying it after a fair amount of maintenance, including new pads for the Tracy O'Brien brakes. I've only done three flights (including a few touch and go's) on the new brake pads, but the brakes have faded into non-existence. At this point the brakes only generate heat and stinky-ness. They are so bad that I will not fly it until this is resolved. It has the stick mounted brake handle and it feels solid with no mush, so it seems I'm into major glazing.
I will be calling Tracy O'Brien to discuss the situation, but I would appreciate any insight that any of you may have.
John
JohnF
Re: Tracy O'Brien brakes not braking
Postby daleandee » Mon Sep 29, 2014 11:51 am
JohnF wrote:I've only done three flights (including a few touch and go's) on the new brake pads, but the brakes have faded into non-existence. At this point the brakes only generate heat and stinky-ness. They are so bad that I will not fly it until this is resolved. It has the stick mounted brake handle and it feels solid with no mush, so it seems I'm into major glazing.
John
Hi John,
I have the exact same set-up as you report. When I first installed mine I thought I had done a fair job of getting the brakes bled but after having to refill them after adding the wheel pants (braked had to be removed to mount the backing plates) I realized that although the handle felt solid I did have air in the system. It was in the stick mounted master cylinder as I have the translucent lines and can see any air bubbles. Inverting the master cylinder while bleeding helped tremendously.
Many have noted that the TOB's fade pretty quickly under hard braking with a heavy aircraft. My aircraft is probably a bit heavier than most (Corvair power) but at 70 hours I find the TOB's to be adequate. The secret for me was learning to slow the airplane down on landing and not use so much braking. In this landing video you can see I'm in the mid 50's for airspeed over the numbers, and the tire chirp happens at an indicated speed of 36 MPH:
http://www.youtube.com/watch?v=WjA7JDJVKeQ
Admittedly I use the LRI (lift Reserve Indicator) more than the ASI but my point is that perhaps, being fairly new to the airplane, you are landing too fast and working the brakes a bit too hard. Still I will concede that the Tracy O'Brien brakes leave a bit to be desired but I have managed to learn to live with them. Mine work quite well after bleeding them ... so much so that they now hold when I do a run-up to 2800 RPM. During a recent landing with the CG very near the forward limit (full tank, solo,no luggage) as I was braking hard to make the first turn off I heard a tire grab and felt the tail get light. They had not happened before. Needless to say I had the stick all the way back but got off the brakes rather quickly. :oops:
Dunno if this helps,
Dale
N319WF
Postby sonex293 » Mon Sep 29, 2014 1:36 pm
I'll concur with Dale about the TO brakes. The have really good holding power and I learned to pulse them to extend their braking capability. But they would fade if used too much. Like Dale, I learned to slow the Sonex down on final and relied more on gravity than brakes.
ex N293SX
Michael Crowder
ex- Sonex N293SX
Current - Just Highlander N371EM
sonex293
Postby JohnF » Mon Sep 29, 2014 3:09 pm
There is no doubt that I am coming in hotter than I should be, and I will refine my landings with practice, but the brakes still seem to be marginal. Should I have followed a procedure for bedding the pads after replacement? And if I got them glazed over from my over-zealous landings, is there any way to get them back in shape?
As to the bleeding issue, what is the recommended procedure and what kind is the fitting is on the brakes so that i can procure the mating fitting?
John
JohnF
Postby fastj22 » Mon Sep 29, 2014 7:58 pm
I also have TOB brakes. I switched from Great Plains disc brakes when I converted to a tail dragger. The GP brakes were so strong, I had to be careful not to lock up a tire on landing. I went with the TOBs because I also bought the TOB gear legs. They mate nicely. I also didn't like the squeaking I was getting from the GPs while taxiing.
The TOBs barely hold during runup at full throttle. They work fine during taxiing and light braking on landing and are smooth and quiet. I'd like more holding power, but they seem to be fine for me right now. The GPs sit in a box waiting for the coach to give them a second chance.
Postby sonex293 » Mon Sep 29, 2014 8:28 pm
I had no problem with holding power of the TO brakes with my Jab3300. I could do a full power run-up and it wouldn't move an inch... I was able to latch the brake handle on my flaps motor for a nice parking brake.
fastj22 wrote:I also have TOB brakes. I switched from Great Plains disc brakes when I converted to a tail dragger. The GP brakes were so strong, I had to be careful not to lock up a tire on landing. I went with the TOBs because I also bought the TOB gear legs. They mate nicely. I also didn't like the squeaking I was getting from the GPs while taxiing.
Michael Crowder
ex- Sonex N293SX
sonex293
Postby fastj22 » Mon Sep 29, 2014 9:25 pm
What master cylinders did you have? I have Hagars.
Postby Bruce593SX » Mon Sep 29, 2014 10:18 pm
I'm in the process of installing mine, the instructions talk about making sure the bleed valve on the master cylinder is in the up position when bleeding while pumping fluid in from the brake.... Warns that air can become trapped in the master if not, especially using the stick mounted MC.
Bruce
Sonex 593
plans building since 2006... Maybe fly this spring......
Bruce Johnson
Sonex 593 AeroVee Turbo
Bruce593SX
Postby rbarber » Mon Sep 29, 2014 10:58 pm
I have TO brakes and matco master cylinders. After 637 hours, here is what I have learned about them: shortly after installing new pads, you will have to remove a spacer washer to keep the gap between the disc and pads correct. Otherwise you will have to pump them quite a bit to get full function. Also, they will get hot quick and take a while to cool off. If the gap between the pads and rotor is at the minimum, they will stick a bit when hot, and have diminished maximum braking power. They still work, just not as well as when cold. I have met several folks who have them, but didn't know how to adjust the gap. If you don't adjust the gap, you will get poor performance.
rbarber
Postby sonex1284 » Mon Sep 29, 2014 11:05 pm
I had a similar issue. Turns out that I had mounted the TOB brakes with the 2 vent ports at the 3 and 9 o'clock positions. I think a big air bubble was present between 2 and 10 o'clock. I took the brakes apart, got an additional fitting from Tracy, tapped and installed it at the 12 o'clock position. It helped a lot.
Mike Kelley
The Villages, FL 32163
Sonex 1284, N154MK, Tri-Gear w/Jab 3300
sonex1284
Users browsing this forum: No registered users and 52 guests
