Sonerai13 wrote:One thing, a major thing, that nobody has brought up in this conversation is the propeller. Even if the engine was the right weight (it's not) and the right physical size (it's not, especially for a Onex), and if you didn't have to engineer an engine mount for it (which you do), you still need to consider ground clearance for the propeller. An O-200, or a C-90 (or even an A-65) produce their power and torque in the range of about 2300 to 2700 rpm. In order to make that power at that rpm useable, the engine needs to swing a 72 to 74 inch propeller. That's 20 inches (!) longer than the 54 inch props typically used on the AeroVee or Jabiru. That means the prop is 10 inches longer on each blade. That would put the prop tip about 2 inches from the ground on a Onex or 4 inches from the ground on a Sonex TAILWHEEL airplane, and closer on a tri-gear. And that's on an empty airplane, sitting still in the hangar. Put some weight in the plane and start taxiing and see how long you make it before you catch a prop tip on the ground. And don't forget to take off and land ONLY in 3-point attitude, lest you hit the runway with the prop.
Sure, you can run a shorter prop, but now you have to turn up the rpm in order to get the performance. Yes, the O-200 can turn more than 2700 rpm, but running constantly at higher rpm will shorten the life of the engine accordingly. And when you do need to top or overhaul the engine, think about the cost. One cylinder assembly for an O-200 costs about as much as EVERYTHING you need to overhaul an AeroVee. Two cylinder assemblies for an O-200 cost more than as EVERYTHING you'd need to overhaul a Jabiru 3300. And you'll be totally on your own in figuring out just what prop will work, which will probably entail buying and trying several propellers before finding the right one. Don't forget to add that to the cost of engineering your installation.
There are a number of engines that can be engineered to fit the Sonex or Onex. But for many reasons that have been outlined in this thread by myself and others, I truly do not believe that the O-200 is among them.
As always, your mileage may vary.
