Tach Sender
Tach Sender
Postby racaldwell » Thu Jan 21, 2021 6:53 pm
Can anyone tell me the make and model # of the tach sender for use on a Jab or CAMit engine? I thought mine would come with one but I was wrong.
Rick Caldwell
Xenos 0057
racaldwell
Re: Tach Sender
Postby Rick524 » Thu Jan 21, 2021 11:54 pm
The Camit tach sensor was designed by Brian Anderson of New Zealand. It uses a small hall effect ic and some components.
I built one and use it on my Jab. Camit put it in a nice alum package and used them on their engines. I doubt they are
available now. If you want to make one, I can dig up the schematic and send it to you. -or- you could use a Honeywell gear
tooth sensor #32315204. It has been used successfully on a 3300 Jab by a Zenith builder named John Austin.
Rick
C-GRIX
Rick524
Re: Tach Sender
Postby Rick524 » Fri Jan 22, 2021 12:05 am
Rick524
Re: Tach Sender
Postby racaldwell » Fri Jan 22, 2021 9:46 am
Thanks Rick. I'll give the Honeywell sensor a go.
Rick Caldwell
Xenos 0057
racaldwell
Return to Other Engines
