Correct Engine Oil for VW
Postby WesRagle » Sat Aug 10, 2019 7:22 pm
Guys,
The documentation that came with my engine instructs me to use 20w50 racing oil. Aeroconversions AeroVee manual says to use "Brad-Penn Penn-Grade 1 Racing 20w50". What I get when I google "Brad-Penn Penn-Grade 1 Racing 20w50" is "Penn Grade 1 SAE 20W50 Synthetic Blend Performance Engine Oil".
Ref. https://www.speedwaymotors.com/Penn-Grade-1-SAE-20W50-Synthetic-Blend-Performance-Engine-Oil-12-Qt-,136581.html?sku=6332050&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=CjwKCAjw1rnqBRAAEiwAr29II9yoPcUi4iOTOWiFzuRHoLqLP4cwUPjGXXaU2YFc4MIRDzUzoq8KohoCoecQAvD_BwE
Is this the right stuff?
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Re: Correct Engine Oil for VW
Postby rizzz » Sat Aug 10, 2019 9:03 pm
WesRagle wrote:Guys,
Wes
I believe it is, I recently ordered a box from the same place I always get mine and was surprised the bottles now look like this. I think they just changed the look.
It is still “the original green oil” :-)
Postby Outlaw6 » Sat Aug 10, 2019 9:25 pm
That's the stuff. New packaging design.
Waiex N176WS (Tri-Gear Aerovee Turbo)
Outlaw6
Postby WesRagle » Sat Aug 10, 2019 9:52 pm
Thanks guys. That is what I'll get.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby rdsafe » Sun Aug 11, 2019 9:21 am
OK Guys;
Explain this to me - from the latest AeroVee manual:
"Synthetic oils are incompatible with 100LL fuel and must not be used."
I'm not trying to start anything here - just wanting the get the right information.
Has anyone inquired w/the Sonex people.
Thanks, R. Stauffer
rdsafe
Postby Rynoth » Sun Aug 11, 2019 10:08 am
rdsafe wrote:Explain this to me - from the latest AeroVee manual:
I'm not sure if that was a quote from an older manual version, but the latest guidance is to not use FULLY-synthetic oils.
Here's a snip from the Aerovee Turbo SB published in 2016:
"new service bulletin ACV-SB-091616-2 states that Full-Synthetic oils may no longer be used in any AeroVee Engine due to incompatibilities with leaded aviation fuel and Full-Synthetic oils. Specifically, Valvoline VR-1, 20w50 synthetic and Mobil 1, 15W-50, are no longer approved. Semi-synthetic oils with high zinc and phosphorus content should be used. "
Postby Brett » Sun Aug 11, 2019 10:09 am
Just google it and decide for yourself.
On a side note.. all the testing I have done with oils... the fully synthetic ones seem to run notably hotter Cht's... I switched back to semi synthetic.
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Postby GraemeSmith » Sun Aug 11, 2019 12:54 pm
rdsafe wrote:OK Guys;
Many years ago - Mobil paid out to repair a lot of engines that were ruined in 50 hours or less using their fully synthetic aviation oil which cannot absprb the lead.
The problem hasn't gone away.
A semi oil has at least some mineral oil to carry away the lead. An all mineral nase is the better bet again.
Postby NWade » Sun Aug 11, 2019 1:24 pm
1) The factory recommends a specific oil for a reason.
2) As a homebuilder it’s best to educate yourself on these topics, not just rely on hearsay from people who have an unknown amount of experience with the subject or your particular aircraft/engine/etc.
Here’s s good article on oil from Mike Busch, a respected A&P who writes articles, and gives free webinars and Oshkosh seminars for EAA & AOPA:
https://www.savvyaviation.com/wp-conten ... ut-oil.pdf
—Noel
Sonex #1339
Postby chuckster » Sun Aug 11, 2019 5:22 pm
As per Kerry just the other day. Aero vee non turbo. Valvoline vr-1 20w-50 non synthetic
Brad Penn grade 1 racing 20w 50
chuckster
Return to Other Engines
