MW Fly Engines
MW Fly Engines
Postby casper123 » Thu Oct 26, 2017 3:55 pm
In case you missed us at Oshkosh this year, I thought some of you might be interested in a picture of our MW Fly powered Sonex.
Hope you like it.
Lance
casper123
Re: MW Fly Engines
Postby Kai » Fri Oct 27, 2017 1:50 am
Beautiful!
Which MW engine model?
Any performance numbers yet?
Kai
Sonex A #0525- SG, DS.
Kai
Re: MW Fly Engines
Postby Brett » Fri Oct 27, 2017 9:29 am
Looks nice,,,,, but what’s the go with the tiny intake for cooling in the cowl?
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Re: MW Fly Engines
Postby kmacht » Fri Oct 27, 2017 12:31 pm
They are liquid cooled engines. If you look at the lower cowling you can see a large rectangular cutout for the radiator. I talked with them at Oshkosh. It is a very cool engine with fuel injection and a fadec. The down side was that they were in the 20k+ price range not including things like the prop, engine mount, cowl etc. They do meet the 200lb weight restriction specified by sonex.
Re: MW Fly Engines
Postby Bryan Cotton » Fri Oct 27, 2017 1:07 pm
Here is a picture I took.
Re: MW Fly Engines
Postby casper123 » Fri Oct 27, 2017 7:20 pm
Hi folks, thanks for the interest.
The engine is the B22d, ungeared, 100 hp. We remapped the engine to put out 106 hp and rotated the air intake pipes back and down in order to fit (almost), the Sonex cowling. There is a little bulge on the top with a small NACA inlet in it for the FADEC unit. Cruises is 118 knots, top speed 126 knots. These numbers were on day which was pretty close to standard atmosphere and at a gross weight of 1150 lbs. I think we could use about 2 inches more pitch on the prop but otherwise the performance is not bad. Climb at full gross weight of 1150 lbs is about 950 fpm. At aerobatic weight it is about 1150 fpm.
Note for Brett, the little intakes serve almost no purpose. Although they do allow in a small amount of cooling air. As the engine is totally liquid cooled, the prime reason for them being there is to allow access to the pins in the piano hinges holding the cowling on :-)
Note to Keith, the weight is a little bit over what the folks at Sonex would prefer. We pulled the engine in as tight to the firewall as we could. When empty, the center of gravity sits right on the forward limit so any weight we add moves it aft. All in, including prop, spinner, all accessories and fluids we are about 223 lbs. This is an installation we wanted to do as we are fans of the Sonex and one came available in our area. At this time it is not an installation supported by Sonex. As a result, we tend to refer to the plane as the "City of Milan", as an homage to the engine's place of origin and out of respect for the good people at Sonex.
Cheers!
Lance
casper123
Re: MW Fly Engines
Postby Kai » Sat Oct 28, 2017 1:19 am
Lance- great!
Thanks for the info, and enjoy your plane!
Kai
Kai
Re: MW Fly Engines
Postby casper123 » Sat Oct 28, 2017 8:55 am
Thanks Kai,
Hope to see meet you at a fly-in someday soon.
Cheers,
Lance
casper123
Re: MW Fly Engines
Postby casper123 » Mon Oct 30, 2017 8:44 am
Here is a little video clip from back in May. GVNZ at our home base in Carp, Ontario. 150 mph on the clock. It is turning out to be quite the little hot-rod.
https://www.youtube.com/watch?v=PgXagw320Rw
Lance
casper123
Re: MW Fly Engines
Postby casper123 » Sat Dec 30, 2017 10:43 am
https://www.youtube.com/watch?v=l9epoiptEUU&t=32s
A little amusement to finish off 2017. Happy New Year everyone!
casper123
Return to Other Engines
