AeroVee Fence baffles on a 2400cc Hummel style engine.
Postby rizzz » Sun Oct 12, 2014 8:22 pm
I decided to buy the AeroVee “Fence” baffles even though my engine is not an AeroVee.
My engine has the Hummel 94x86 Nickasil plated aluminium cylinders so the engine is a touch wider than the AeroVee and the Cylinders are shaped differently.
All this meant modifications would be required and in the end I remade the back fence baffle and the two front corner baffles. The other parts fitted as designed.
It was great still having the AeroVee kit, even for the parts I had to re-make the AeroVee parts gave me a good starting point, it would be a pain to have to design this from scratch.
You can see some pictures of the semi-finished product here:
http://vwaircraftengines.com/viewtopic.php?f=13&t=21797
Re: AeroVee Fence baffles on a 2400cc Hummel style engine.
Postby rizzz » Wed Oct 15, 2014 5:23 pm
Added a few more pictures of the manifold cut-out and the oil cooler baffles:
http://vwaircraftengines.com/viewtopic. ... 482#p76482
As none of this is according to any plans anymore, this work is a little bit of "trial and error", I might have to remake the back fence baffle again to get a tighter fit around the manifold.
Postby rizzz » Thu Oct 23, 2014 6:28 pm
Had to do a few more modifications, added ome more pictures here:
http://vwaircraftengines.com/viewtopic. ... 483#p76483
Postby rizzz » Sun Nov 02, 2014 6:51 pm
Return to Other Engines
