I trust that there will be no objection if I copy a couple of posts about the Corvair that are hidden under the Continental O-200 thread. Here you will find some good information and insight into the make-up of the Corvair engine. I agree wholeheartedly with his point about William Wynne. William himself has made it clear that, "you don't have to like someone to learn something from them."
As an aside to the engine failures that are discussed in the second post below ... many know that like the earlier VW conversions, Corvairs went through a period where cranks were being broken. That is history as there are brand new stock and stroker billet cranks available as well as Nitraded and properly machined & reworked 8409 GM cranks. William now requires a 5th bearing to be installed on engines built to his specifications. Some Peitenpol builders have not used the 5th bearing and while they had no issues for many years, now it is highly advised that all Corvair conversions install a 5th bearing. Besides it's just good sense!
I fully understand the frustration he speaks of about the many Corvair experts that have never seen, worked on, converted, watched fly, or flown behind a Corvair engine converted correctly for aircraft use. To any that have a genuine interest in the Corvair engine for aircraft use I would again urge you to go to some of the links provided in this thread and begin to do a bit of serious research. As noted before, this isn't the engine for everyone and other great choices are available. This is the one I choose to use. If I can help you, I will.
Hope this helps,
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
166.7 hours / Status - Flying
Re: Continental 0-200
Post by Jgibson » Mon Aug 14, 2017 6:55 pm
I'm sold on the Willliam Wynn Corvair and would build with nothing else. It can be built cheaper, or go full tilt with a new forged crank and 92mm barrels and come in lighter than the O-200.
It was designed to make up to 180 hp at 5500 rpm, and is loafing in the aircraft version. William is eccentric, however he tests his products intensely. No need to engineer a motor mount because his business partner Dan sells them ready to go. The new 5th bearing setup is well engineered and well made.
Standard Marvel Shebler carb, redundant ignition, no junk Chinese parts. I've actually TRIED to blow a turbo model in a car up without success.
Zenith has embraced their engine and supplies EVERYTHING necessary for a full install down to cowling, exhaust, etc.
Dan built the first 'Cleanex' and now offers nose bowls, exhaust, mounts, and almost everything necessary to do the install on the Sonex. But still Sonex stonewalls their product.
Remember that there are almost NO old parts in the Corvair airplane engine. Cases, oil pump accessory case, and if you choose to build frugally, the forged crank that GM spent 100's of millions to develop.
A 100 hp model just sold on Barnstormers WITH a new Dan Wessman crank and rods, exhaust, carb, intake, baffling for under $6,000. Models can be built up to 125 hp with Dan's new 'stroker' crank.
And remember: an engine that was DESIGNED to run at up to 5,500 rpm.
I just don't get Sonex' resistance unless it's purely personal with William. I'm not buying someone with a 'normal' personality. I'm buying a bullet-proof engine that I trust my and my loved ones life.
I have NO CONNECTION to either William or Dan. But I've been a fairly decent aircraft mechanic and restorer for the past 40 years and have a lot of experience with a lot of different power plants. The LAST one I'd consider a potential candidate for aircraft use would be the VW.
JMHO
Jgibson
Post by Jgibson » Tue Aug 15, 2017 8:51 am
I challenge Kai to find me NTSB reports of Corvair quitting because of the basic engine core itself.
Any that I researched quit because of failure of support systems (carb). And your issue with balancers is....? Do you mean like the crank counterweight balancers and/or flywheel balancers used on 'certified' engines? When building a new Corvair, of COURSE a new balancer is used. And have I seen balancers go bad? Of course......after THOUSANDS of miles and many many years of hard use.
And 5000 rpm short bursts? Bogus my friend. Read up on the racing history by Don Yenko and Fitch when those engines were running SCCA races for hours on end.....WITHOUT FAILURE.
But let's for a moment agree that 5500 would destroy the engine: so what would running it at 3,000 do while still making 100 hp or more?
Wynn modifies one of the weak points in Corvairs; that of the distributors. They were originally produced with a single bushing in the distributor which after years of use or extremely hard use at high rpm would allow the distributor shaft to 'walk' and skew timing. Eventually that 'walk' would wear out distributor gears. He modifies the oil pump system, and uses nothing but aircraft carbs WITH CARB HEAT (which is absolutely necessary) Some of the other 'builders' did none of that. But their engines were very pretty on the outside.
And if you try hard enough, there's always the chance something will fail. NOTHING is 100 percent guaranteed. If you don't believe that, ask the poor guys who bought BRAND NEW Lycomings who now have garbage rod end bushings that will facilitate replacing the rods. Or guys like me who have had Lycoming change their oil pump gears three or four times now that forced me to tear into the engine to correct.
William uses redundant ignition, redundant coils, correct baffels, aircraft carbs, aircraft hardware where applicable.
There were 2 or 3 other converters of Corvair engines that used junk parts and questionable techniques and for those I won't speak. But the testing and thoroughness of WW is second to none.
If you search the internet, you'll find MANY Corvair EXPERTS who have never owned one, never run one, and have never torn them apart. I've done all of the above. And like I said in a previous post: I intentionally TRIED to blow up a 150 hp turbo motor (factory setup) by running it wide open until destruction....
And it just kept running.
I've worked on and torn apart just about any aircraft engine you can name (well okay: not a Franklin) and I'm personally convinced that WW's version is as good an engine as any IF it's built to his standards and IF nothing but the best (proven) parts are used. Not junk overseas parts that LOOK great and are a good price or are acceptable for auto use.
Jgibson
