SonexN76ET wrote:I bought mine from Amazon, but verified it was the same stuff Aircraft Spruce was selling. It is Thermo-Tec 14620 60" X 36" Heat and Sound Suppressor. The product states: "
In addition to the polyethylene film the foil surface provides direct protection from radiant heat
Great for areas like firewalls, floorboards or doors
The Suppressor is also 70 mil in thickness, contains a high temperature adhesive backing and is easy to trim and fit
The Suppressor will reduce various road noises, engine noises and improve driver comfort and concentration"
I put the material on the inside of my firewall and on the floor up to the mid point between the spar and the firewall.
I also put a 8x8 inch square on the floor under the luggage sling and an 8x8 inch square on the floor in the section behind the luggage sling.
I am also going to experiment with putting an X made up of the material cut out of 2 inch strips on the side panels in the two forward sections of the tail (baggage compartment and section behind baggage compartment. I hope that these X shape cut outs will stop the oil canning and resonance in the tail without adding undue weight.
I have noticed significant sound and vibration reduction. It is still very loud at wide open throttle, but any power settings below that are significantly more quiet.
I also put weather stripping around the canopy. This cuts down on drafts and wind noise and keeps the cockpit dry.
Jake
