Oil Pressure Confusion
Re: Oil Pressure Confusion
Postby WesRagle » Sat Feb 15, 2025 9:29 pm
Hi Guys,
Here is what I found when I removed the Oil Cooler.
The oil cooler is rated for 150 psi.
Have you inspectex the oil pump? If the clearances between the cover plate and the gears gets excessive the pump will lose pressure as the oil thins and it seeps past the gears.
No, I have not. That will be next.
32psi is actually pretty good at 2500 rpm.
I agree, but it just keeps dropping. I'll keep a close eye and just shut down and let it cool when it drops below 20 psi.
What I think I'll do first, is get back to where I was before I got over zealous with the relief valve. The only issue I have left, that the test engine can help with, is investigating/verifying the input signal conditioning circuit for the alternator input. That won't require extended runs. I can fully investigate and fix this problem at a later date.
Thanks For the Help,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Dave Wolfe » Sat Feb 15, 2025 9:34 pm
Heres the page from the GP manual:
Dave Wolfe
Postby WesRagle » Sat Feb 15, 2025 9:51 pm
Hey Dave,
I think that 28 psi @ 2500 rpm and 158 F is direct from VW back in the day. I find the same repeated on page 40 of "How to Rebuild Your Volkswagen Air-Cooled Engine". I'll get a new cooler installed, put things back like the were, and keep an eye on it.
Thanks Again,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Return to Other Engines
Users browsing this forum: Bing [Bot] and 6 guests
